I have the same thing. If you look up under the dash there isnt really any insulation up above the carpet and there isnt insulation on the trans tunnel. The exhaust runs right through this area so if you are driving for a while i think the heat just comes through the metal and into the cockpit. That is what i tell myself anyways.
I guess that what it is, does it feel like it is blowing on your leg like the older cars use to have when they had vents.Have they come up with any solutions for this.
My car had the same problem i found that the shift rubber boot was not in all the way Just remove the shifter cover and look at the shifter This might be the problem . Good luck
