Rattle From left Rear of Car...
I have taken my 06 GT to the dealership 2 or 3 times now and they cant figure out what it is(Something loose or a shock).....Has anyone else on here had the same problem?.....Like it says in the subject the noise is coming from the rear left side of the car......
RE: Rattle From left Rear of Car...
At idle? At a particular speed? All the time? Over bumps? Sitting still? Going uphill? Downhill? (...fingers getting tired...). No wonder the stealership can't figure it out.
More info!
More info!
ORIGINAL: Nuke
More info!
More info!
Mostly over small-large bumps.....Sounds too high to be exhaust....When I took it to the dealership the one time they put a new bushing on the shock but that didnt do it so that eliminates that....
i started getting this after i installed my axle backs. The hanger is a tad too long and it rattles off the rear of the car. Dremel with a cutting wheel should do the trick. what exhaust are you running?
Good info guys, but i have a question that is similar. Mine makes noises going over bumps and stuff like that, but it also makes a slight rattle when i am coasting downhill. It is apretty mild noise and doesnt even bother me, but if it is aneasy fix, why not? I will check out the muffler rattling and i have already check on my lcas and they are nice and tight. Has anyone else had probs with rattles while coasting? if so how did u fix it.
