Line Locks and install kit. Which brand???
#22
RE: Line Locks and install kit. Which brand???
ORIGINAL: TASSY5
How well does this kit Fi with a CAI mounting in the same area????? I have a C&L CAI
ORIGINAL: 07SCGT
Here is a pic from granatelli's web site, I use the same line locks and it has plenty of room without hitting the intercooler hoses. I would have sent you a pic of mine but 2 things have to happen,
1. Finish my coffee
2. Wash the engine compartment before I take any pictures of it, ( I know how you guys are).
If you want to see a different angle, I will be willing to do a close up from the top down view, just let me know.
I personally went with granatelli motor sports because it's a dual silenoid system, not just 1.
1. Finish my coffee
#23
ORIGINAL: nineinchnail1024
I have the C&L CAI and the new lines will interfere with the heat shield. There are two solutions. You can remove the heat shield, or you can do what I did, use flex brake lines in place of the solid brake lines and route then below the heat shield. Used them several times with no issues.
ORIGINAL: TASSY5
ORIGINAL: 07SCGT
1. Finish my coffee
1. Finish my coffee
Thanks,
TASSY5
#24
OK Jegs has the duel Granitelli tire fryer kit for $242.00 Is there any other parts i need to buy besides some braided brake lines to re route from my CAI AREA??
#25
242!! I swear you can get it for like 170
Nevermind...that must have been the price i saw in a for sale section a while ago...you can probably get it a little cheaper but not be much
#26
http://www.jegs.com/webapp/wcs/store...8_-1_11247here is the link from Jegs
where can i get if for $170 ????
#28
My intercooler piping comes right through the middle of the GMS kit.
I don't have my car right now so I can't go out and look at it to see. I want to say my 06' looks little different than your 07'.
I think I'llbe going with the PMP kit. I read up on it at there website and saw you needed to by two solanoids from Summit or Jegs for $35 each. Total cost of kit is around $100 if I remeber correctly. Maybe some wiring also.
#29
I will be picking up a kit in the spring looks like granetelli(ugh) or pmp which is not complete which I am not a fan of. There has to be some better choices out there.
#30
Years ago when I ran a Fox body I had the Hurst Roll controll system on it. It was fine for the job and never gave me a problem, but install was a pain because of having to fab lines for hook up.
As for the PMP, yes Jegs silinoids are cheap at $35 bucks but then you have to piece everything else together. The Granitell Tire Fryer system seems to be a complete << system and Obviously since I have a CAI I will have to buy some Braided lines to reroute the system since the solid lines will be harder to do. I just want a Good system and yet a complete system out the box with not figiting around for parts to make the system work. It isbad enough Iwill have to get braidel lines fo some of the application but i guess it will give it a more attractive appearence when installed.
ANY>>>Opinions on the Granitelli system from youwizards is appreciated, if you have they system and can give straight facts on the install and quality.
