whipple videos......
Some people, including aeroforce, told me this gauge would only show the pressure drop accross the injectors which should always read around 39psi. Well here is proof that it does indeed show actual pressure at WOT. Just before each shift it hits 75.6psi, this was the end of second gear. Just before this frame it actually showed 58mph, i guess I lost a mph when I went to shift.
ORIGINAL: 06Saleen3V
How do you miss 4th? I think that is the easiest gear to hit...[&:]
Moose... nice whine!!! can't really see the gauge at all
I've had the same issue.... it appears from the reading I've done its not that uncommon. I think I'm going to add a CHE k member with torque limiters to prevent the movement in the tranny that seems to cause the shifting issues.
ORIGINAL: Boss919
I have a problem missing fourth gear. I'm not sure why but I seem to miss that onemore than any of them.
ORIGINAL: moosestang
I do find 4th pretty easy. If you push up with the palm of your hand for 3rd instead of gripping the shifter like you're holding a baseball, it will hit it every time. Damn opposable thumbs![:@]
EXACTLY!!
ed wine = $2.50
White wine = $2.50
Whipple Whine = Priceless
White wine = $2.50
HAHAHAHAHAHA YES!!
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
01roush33
May 26, 2006 09:32 PM
. Sounds sweet man! -Jon
