What Bolt-Ons Would You Suggest To Buy Next?
Not anytime soon, but say a couple years down the road I plan on getting a Saleen or Kenne Bell Supercharger installed.
But, in the meantime I'm N/A, what performance mods would you suggest adding next to my car?
Some ideas I have been thinking about are:
1) Torque Converter (TCI Super Streetfighter, P.I. Stallion, Level 10 Stage 3)
2) Steeda Charge Motion Control Delete Plates (economy or billet) (worth it or a waste?)
3) Steeda UDP's (again, worth it or a waste?)
(I have NO plan of adding ANY additional battery/amp hungry subwoofers, in-dash tv's or other electronic bs in my car)
4) ARH or Kooks Long Tube Headers with Catted X-Pipe (not sure what size, 1-3/4 or 1-5/8?)
5) Suspension (Steeda Front Swaybar & Steeda Rear Heavy Duty Swaybar, Eibach Pro-Kit Springs, Tokico D-Spec Shocks & Struts)
6.) Electric Water Pump (who makes it & where would I even buy one at?) (also, worth it or a waste?)
Please give me any suggestions and/or comments.
RE: What Bolt-Ons Would You Suggest To Buy Next?
ORIGINAL: 2006gtmike
2) Don't. The installation of your twin screw will replace these.
3) Don't. The KB belt system replies on the stock pullies
4) I haven't done these yet but when I do it will be 1 3/4" primaries. However - I would not put these on before the S/C as 1 3/4" primaries will probably hurt your N/A performance.
5) Coolness.
6) No.
I agree with the Suspension thumbs up. A few thougts for you though: If you haven't already done so go over the the v8 Handling Section and read up. There are strong recommendations that you don't get the front sway bar, rear - yes but not the front unless its fully adjustable. The stocker is too stiff as is. Also note that with the Eibach Pro it will drop your car enough to need more items to bring the suspension geometry back to spec (assuming you want a great handling car): camber adjustment (plates or camber bolts); Adjustable pan hard bar, adjustable lower or upper control arm (to reset pinon angle); probably a bump steer kit on the front or other parts to reset the front geometry.
Right now I'm putting in the Eibach Pro and D-specs - I want a very good handling car and thus I'm finding this to be an expensive proposition, count on about 1500 - 2K to do it right.
I already have the Steeda 555-4106 Adjustable Competition Upper Control Arm and 555-4422 Steeda Chrome Moly Steel Lower Control Arms installed.
You already have upper and lower control arms, which are the most critical suspension upgrades.
Why not start saving for the supercharger?
If your ultimate goal was to stay naturally asiprated, then I could understand picking through the bolt ons. Otherwise, why bother?
Suspension mods are a plus, I would take the money that you would spend on headers and apply it toward a S/C fund, the cars breathe really well with the exhaust it comes with. I have the electric water pump with my Saleen S/C, nice if you go to the track. Also a fund for some big sticky tires if you go S/C.
