O2 sensor problems
Old Dec 2, 2007 | 08:32 PM
3vBlackStang's Avatar
3vBlackStang
Default O2 sensor problems
I have a 2005 mustang w/ some mods and my check engine light came on. The code description is O2 sensor bank1 and bank2 slow response time.
had custom bosch sensors and went back to stock sensors, but light still comes back.
Old Dec 2, 2007 | 10:07 PM
godminus1's Avatar
godminus1
Default RE: O2 sensor problems
Do you have long tubes? After I had my long tubes installed I get that occasionally. I believe its a P1033. Basically with the extensions it takes the signal a slight bit longer to reach the ECU. This will throw the light. I had my tuner do something and it decreased the occourance. Not sure what it did. It's nothing to worry about.
Old Dec 2, 2007 | 11:00 PM
3vBlackStang
Yes I do have long tubes, thanks for the reply.
[/align]
Old Dec 3, 2007 | 05:53 PM
onederful100's Avatar
onederful100
i had the same code after installing LT's and o/r x-pipe. i kept on clearing the code, but it kept coming back untill i reloaded the tune instead of clearing the code then it never came back again.
Old Dec 3, 2007 | 10:34 PM
3vBlackStang
I have reloaded the tune and since then have had a dyno tune, it must be the extensions.
[/align]
Old Dec 4, 2007 | 04:45 PM
onederful100
so did the code come back?
Old Dec 4, 2007 | 05:03 PM
ProCrsh's Avatar
ProCrsh
my friends father ran into the same problem when he changed over to long tubes. the shop he goes to sold him i want to say o2 deletes with a tune and hasnt had a problem since. cost him about 125 150 installed. i could find out more if you interested
Old Dec 4, 2007 | 09:00 PM
2k6silvergt's Avatar
2k6silvergt
I had the same problem after I installed longtubes and a midpipe on my car. Didn't really happen all that often so I just cleared it with the tuner when it popped up.
Old Dec 5, 2007 | 10:05 PM
3vBlackStang
Yeah it came back, I'm going to try taking some wire out of the harness and see if it will reach the sensor then.
[/align]
Old Dec 5, 2007 | 10:09 PM
3vBlackStang
Thanks, but I only have two sensors on now without the cats, and I can't put simulators in place of them.
[/align]
[blockquote]
ORIGINAL: ProCrsh
[/blockquote]
