Supercharger ?s - Plugs, high octane ?
Getting dangerously close tobuying a SC, I have a couple of questions.
Do I need to run colder spark plugs?
Do I have to run with higher octane fuel?
Really want to keep87 octane unless it is totally required !!
My current tune is Brenspeed 87 octane
Any help would be appreciated
RE: Supercharger ?s - Plugs, high octane ?
It's highly recommended to run colder plugs, but it depends on how much power you will be putting out. The tune dictates the octane but what's the point of not running higher octane which will gain you more power? Willing to spend $3k+ on a mod but not wanting to spend ~$5 more per tank? Not understanding that...
From what I hear you almost always have to run premium gas when you supercharge. And the plugs wouldn't be a bad since they will help prevent the cylinders from misfiring.
I thought detonation was a fuel pressure issue ? Also I heard higher octane only improves gas mileage, with a proper tune, performance wise there is not much of a jump, anyone hear this too or am I crazy ?
thanks
thanks
ORIGINAL: desslok40
thanks
thanks
No, it's not just a fuel pressure issue. Higher octane reduces knock. Basically you need enough fuel and a high enough octane. That's why pro race cars need much higher octane. So they can advance they're timing alot and not have to worry about detonation. Someone could go on all day about this stuff, but I'm not lol
Higher octane fuel is only better if your motor needs it.
If you are stock, then you don't need it. If you are aggressively tuned, have a high compression ratio and/or you are running boost - then you need higher octane.
Higher octane fuel is simply harder to combust than lower octane fuel. So 87 octane will combust easier than 93 octane.
Pre-detonation (pinging) is caused by your air-fuel mixture igniting BEFORE it should. It is lighting from either compression or a highly advanced timing setting. Pre-detonation can put a hole right through your cheap little pistons.
If you use 93 octane it will be farless likely to pre-detonate than 87 octane fuel. The 93 octane won't make you faster. It will just allow your motor to run correctly with more compression (boost adds compression to cylinder) or more timing advance.
So if you are going to join the forced induction club, you may want to re-consider your feeling about the fuel you use. The extra 5 bucks you spend may keep your motor in one piece.
I run 100 octane all the time because I am at 11 PSI on the stock bottom end.
