engine mods to safely increase PSI?
RE: engine mods to safely increase PSI?
ORIGINAL: Turbo_stangGT
uuhh..hhmm..not too excited about yaking out a new motor and replacing it with a built one on a brand spanking new car lol.[:'(]
I will see how much hp will keep me happy on the stock block/sc..450-470whp are still some awesome numbers,not exactly slow or anything...
ORIGINAL: LMM1967
Go buy yourself a block now - start collecting forge internals, build that as a short block, get the car, yank the heads etc, bolt the SC on thatand then place that in your car.
Sell the almost brand new stock short block that came with the carto recoup a portion of your money and help pay for clutch, driveshaft, suspension etc.
ORIGINAL: Simon1
For those who have never expereinced it, that's alot of power. Not saying you haven't but, it's alot. The rotating assembly is the weakest link, rods, pistons and crank. Mostly the pistons and rods. Some will replace head studs and put in a windage tray and add all sorts of supporting mods. The bottom line is the rotating assembly. You can use your own block, but you can also find a cheap used one and replace the guts.
ORIGINAL: LMM1967
If I can just getting away with slapping on a SC on a stock block and make the numbers they claim to the wheels..I just may keep it like that without touching a thing with the safe tune/boost levels and all.
I have fun driving my moms new ford edge and that thing hauls for having only like 250 bhp...I can only imagine twice that much to the wheels and with a smaller car lol.
Who said anything about 16psi? I do know that the stock motor (in particular the internals) have limits. You sound very familiar in the way you write your posts...... I agree you have a wealth of knowledge but in general it is a good fact for lower boost and less than 500 RWHP and every tuner has their own opinions on how to tune and whats causing the internals to blow. (which is where I got the fact from). JMO J
Thats exactly whatI said in slightly different words!
ORIGINAL: modaddict
Come on - that's not accurate. If you gave the car an ultra conservative 9º of timing and ran it pig rich to be the safest possible, you would still send your rods into daylight with 16 psi. tuning is critical, I agree, but even a good tune will destroy your stock motor if you throw too much at it...
For the poster... Cams and everything else in valve train mean nothing. The upgraded valve train only comes into play when you want to spin the car a lot higher. In the case of centrifugal blowers, this is a good way to increase boost levels on the same pulley. No, to safeguard your motor with bigger boost and power levels, you want to upgrade your rods and pistons at the very least.
If you are on a budget, the stock crank will hold for some decent power and the block is fine. Upgrade your rods and pistons and with a good tune, fuel system upgrades, some minor other engine mods you can be knocking on the 600 door.
ORIGINAL: mygt500
I would do the rods and pistons. You are fine with the cams you have and the rods are the weakest link in the motor! JMO but others will chime in. Many agree that 450 RWHP is the limit of what the motor can handle safely (regardless of boost). Remember boost doesn't destroy pistons it is poor tuning w/ resultant detonation that blows motors! JMO J
I wasn't commenting on your recommendations. it was great advice. I was commenting on where you said boost doesn't destroy rods. Boost has more to do with snapping the rods than HP does. I wasn't disagreeing with you - more clarifying what you were saying...
If you look at the guys making 500 rwhp on the stock and the guys making 440 rwhp on the stock motor you'll find the majority are all doing it with 11 psi or less. The difference is some tuners are able to get more safely out of the tunes than others. This is why I don't think saying '450' is a 'limit'. I think it's more accurate to say 10 psi is the limit and whatever your tuner can get safely HP wise out of it is what your 'limit' will be.
To me, boost has MORE to do with what the rods will take then the dyno HP number. That is what I was commenting on from your post. [sm=icon_cheers.gif]
Well -ok can't argue that logic! Makes sense and thanks for the follow -up! J
ORIGINAL: modaddict
The "one big mod" S/C upgrade will get you some serious grins. A complete kit can be bought, and regardless of the brand, you can get an easy 10 psi, without worrying about internals. That 10 psi will put you in the 450-475 rwhp range.
ORIGINAL: SCCAGT
