problems
Old Dec 20, 2007 | 10:06 AM
RED121572's Avatar
RED121572
Default RE: problems
Man, I get a chill up my spine thinking about have a problem like your having. [sm=smiley5.gif]
That sux. I hope you get it resolved.
Old Dec 20, 2007 | 10:36 AM
acascianelli's Avatar
acascianelli
Have you tried recalibrating the throttle? Turn ignition on but no motor, push down gas pedal for 5 seconds(at the end of the 5 seconds you should be all the way down), release for 5 seconds (at the end of 5 seconds you should be completely off the throttle).
Old Dec 20, 2007 | 02:46 PM
ModernMuscle's Avatar
ModernMuscle
didnt help.
Old Dec 20, 2007 | 02:51 PM
hammeron's Avatar
hammeron
hey muscle, i'm starting to suspect that
you have a sensor that's gone belly up.
Old Dec 20, 2007 | 03:29 PM
Dex's Avatar
Dex
yes, check your 02's
Old Dec 20, 2007 | 03:46 PM
ModernMuscle
would the 02s have to do with the forced Idle code.
I checked more in depth of it and it only displays whenever the pcm has to step in and add voltage to the TPS to give the correct reading for idle.
I took care of the code by clearing it, and it hasnt come back.
all voltages (ignition, start, idle, and wot) on the TPS are as they should be.
The sensor is a couple months old, but seems to be functioning correctly.
the only other thing left I can tell is the pcm.
Old Dec 20, 2007 | 03:54 PM
ModernMuscle
update:
car is going to the dealership to be hooked up to the big computer to check in depth...
ill let yall know what we find out.
Old Dec 20, 2007 | 04:15 PM
hammeron's Avatar
hammeron
excellent, please update the thread
when you find out more
Old Feb 8, 2008 | 02:13 PM
MexGT's Avatar
MexGT
any updates?
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
