Auto Meter a/f install question
RE: Auto Meter a/f install question
ORIGINAL: ebr
Does anyone else have this gauge ?
Auto Meter 4378 - Ultra-Lite
Ultra-Lite Air/Fuel Ratio Wideband
ebr, I have the gauge installed and unless your going to data log all you need to do is ground it on the firewall. When your under the car make sure you don't get the wires in a tight bind, like a 180 degree bend. If you find out where to hook it up for data logging let us know.
ORIGINAL: ebr
Sorry I didnt see the post . It is for the WOT . Does anyone know where to connect this wire ?
My instuctions say the blue/black and the blue go to the data logger, the black is the ground, the red is to 12v ignition switch and the brown to the wide open throttle switch (for wide open peak function) as the instruction say.
ORIGINAL: ebr
