UDP failure
Old Jan 9, 2008 | 08:53 PM
Bogey750's Avatar
Bogey750
Default RE: UDP failure
My car went down this weekend because of a bad pulley. I heard a squeal and decided to check everything out and the crank pulley had alot of play in it. You could move it about an 1/8 of an inch back and forth. Lucky I caught it before it came off going down the road. The pulleys are two part with a rubber pressed in. If the pulley comes off going down the road it can tear up alot of sh*t.
Old Jan 9, 2008 | 09:00 PM
ebr's Avatar
ebr
Whos pulley on yours ?
Old Jan 9, 2008 | 09:01 PM
SirKnightTG's Avatar
SirKnightTG
I'm really scared of getting a UDP now.[]
I think I'll pass...
Old Jan 10, 2008 | 01:24 AM
BillyBobJoe's Avatar
BillyBobJoe
ya...wtf? where did all this pulley crap come from. In almost two years on MF I've only heard of maybe one pulley failure
Old Jan 10, 2008 | 07:09 AM
Chevy Convert's Avatar
Chevy Convert
Just my .02 but if I were running a 12K racing motor the last thing on my mind would be running UDP's....Not to say I'd run a stock balancer either but the neglible gains of part designed for the shade tree bolt on enthusiast vs. someone running a hardcore race engine?
I'm not pointing the finger - that really sucks.
Old Jan 10, 2008 | 08:05 AM
blackout's Avatar
blackout
I just read the DTC for this error and it read as follows:
"User Error!"
I also shook my Magic 8 Ball and it agreed with the scan tool.
-Jeff
Old Jan 10, 2008 | 09:04 AM
jrherald420's Avatar
jrherald420
damn!!! dont know what else to say!!!
Old Jan 10, 2008 | 09:14 AM
acascianelli's Avatar
acascianelli
I'm alittle mad now, when I was doing research before I bought these I had only seen two threads of people that had problems with them failing and that was searching through years of past posts. Now all of a sudden people are coming out of the wood works with problems. I've had mine on for only about 2 months and they seem to be fine. But next time I put my car up for maintanence, I'll be sure to see if there is any play in the pulley.
Old Jan 10, 2008 | 10:08 AM
Tormentor's Avatar
Tormentor
Yea I just installed my pullies,and now it makes me want to reinstall the factory ones. I dont want to be stranded on the side of the road, or my wife! Man that would put a screaching hault to any future mods for the car if it happened with her behind the wheel!!!
Old Jan 10, 2008 | 12:50 PM
RodeoFlyer's Avatar
RodeoFlyer
the inner/outer hubs of the pulley were out of alignment by @ 1/2 inch. We had the pulley tested and it was enough out of balance that it could be blamed for the oil pump failure, which at 7k rpm on a road course doesn't give you much time to shut it down and save it.
As I said, this was a Steeda SFI rated pulley/balancer, which came of his previous motor w/ only 24k on it.
I'm hardly saying it's going to happen to everybody. There are a number of isolated incidents amongst who knows how many pullies out there. All I am saying is that 8hp probably isn't worth a 5-8k risk to replace a stock motor, let alone a race one.
