Newbie question
RE: Newbie question
I made 500 rwhp and 425rwtq with the stock pump at 12 psi on a procharger p1 set up , but a word of advise stay under 10 psi if you are stock as that moter is no longer with us . Not due to fuel , but due to broken rod. What set up are you going with and what psi are you starting with ?
RE: Newbie question
Add a prochargers ADD-A-Pump. It piggybacks your stock fuel pump. 03-04 Cobra 39LBS injectors(they are blue)should be what you need to run,I believe. Those are the injectors that I'm running with a Procharger P-1sc-1 10psi.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
