cmcv plates
Old Jan 18, 2008 | 06:31 PM
Leos06gtLL's Avatar
Leos06gtLL
Default cmcv plates
has anyone gutted there stock plates so they can be used a delete plates? If so is it a pain ?
Old Jan 18, 2008 | 06:37 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: cmcv plates
There was a thread over @ TMS...dont know if you saw that or not.....i dont think it worked out to well
Old Jan 18, 2008 | 06:39 PM
NyFordTech's Avatar
NyFordTech
Havent heared of anyone doin it, i dont think it can be done considering if you buy the actual delete plates you need a tune, if it could be done you would prolly need a tune anyway!
There really not much money anyway so i would jus buy them!
Old Jan 19, 2008 | 01:04 AM
Leos06gtLL's Avatar
Leos06gtLL
havent seen it gonna look for it......do you have a link?
I know i am gonna need a tune it just like having a delete ones .........i hope
Old Jan 19, 2008 | 01:10 AM
howarmat's Avatar
howarmat
s197 Junkie
http://forums.bradbarnett.net/showthread.php?t=74502
Old Jan 19, 2008 | 01:47 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Matt's got a link for most everything! Very valuable to the forum no doubt! J
Old Jan 19, 2008 | 06:35 AM
shooter23's Avatar
shooter23
i've heard of it being done, havent done it myself.
Just need to cut out the butterfly valves and silicone the small holes that stay.
and yes, you will need a re-tune because without teh valves, there will be nothing to regulate the air flow.
Good Luck!
Old Jan 19, 2008 | 02:08 PM
howarmat's Avatar
howarmat
s197 Junkie
I think the tune is more for the lack of motor that the CPU would be trying to run.
Old Jan 19, 2008 | 03:49 PM
dirtydeedsinc's Avatar
dirtydeedsinc
Sounds like it took a little R&D but got figured out from what I read. I also got those from Brenspeed on Ebay and they're sitting at the house. I think I'll just cut the blades off then turn the shaft so it doesn't block much airflow, then pin it in place. Probably open the ports up some while I'm there. I should have done this the last time I was home but spent my 2 weeks off swapping hoses, installing strut bar, installing gaugesand installing nitrous. Since I'll only be home 5 days (maybe) this time off it will probably have to wait until March.
Old Jan 22, 2008 | 06:39 PM
Leos06gtLL's Avatar
Leos06gtLL
ORIGINAL: dirtydeedsinc
lets us know how it goes.
still debating between steeda underdrive pulley or delete plates i am gonna buy a set a pay with them if it doesnt work I ll just buy real delete plates
guitarman376
Oct 11, 2015 01:47 AM
Explosive
Oct 2, 2015 07:45 AM
mdg
Oct 1, 2015 07:04 AM
winner99
Sep 30, 2015 07:04 PM
maestro1024
Sep 21, 2015 02:40 PM
