whats next?
RE: whats next?
thanks for the ideas so far. here's a few questions/comments.
1. K-member brace with torque limiters- don't they do the exact same thing the prothane motor mounts do?
2. What will the stainless steel brake lines do? What fluid do you suggest?
Thanks so far for all the ideas. Keep em comin!
RE: whats next?
stainless lines will firm up the pedal and give a progressive pedal feel. Motul Blue fluid. Hawk HP+ pads or HPS ones. It gives you that extra confidence knowing you can stop in a hurry if you need to reign in all that power quick.
RE: whats next?
I agree with most of what was posted above. But I didn't see any DRs on your sig? That would give you a better gain than anything else in the 1/4 with your set up.
You would need some different wheels but other than that . . .
D-specs would help you out. Your stock shocks/struts will be taking a dump soon with pro kit
