I want to do cams!
Im thinking of doing cams in my car. Which brand should i go with and why? Also i heard you can get a 30-40hp increase from doing cams is there any truth behinde that? Also can i do cams now and heads later or should they be done at the sametime? Thanks guys i dont know much about cams.
Depending on which cam application you decide on you may have to get different injectors,fuel pump and a new mass air sensor.Plus use will need a tuner for calibration.Check the Comp Cams website.It gets expensive pretty quick and the labor might include pulling the engine.It the torque you get from a cam upgrade that make a big difference,especially at high altitude.
I am not sure of the actual gains but I have heard a cam upgrade can be as little as 10 HP in our cars. People are steering clear of doing cams becuase when all is said and done you are paying like $2500 or more for very little HP....even if you really do get 40.
I say save up and get a supercharger.
the other mod that should be done with cams are heads and they're very pricey, for the money of cams and heads + spings + retainers + instalation you will be in the 5K range spent, for that coin i'd buy a SC.
alot of people have lost power...
and it doesnt depend on the brand, it depends on the grind...you need to get a cam set-up thats right for you...do you plan on boosting? staying N/A?...is this a strip/race set-up...daily driver only?
40 is not going to happen if you only do heads...youd be lucky for 10...search the forums and read what results people have had...not good...
the only good ones are where people have done all the complimentary mods and have really researched which grinds thye need for their application.
good luck!
good luck!
ORIGINAL: shooter23
good luck!
good luck!
http://www.brenspeed.com/mustang_200.../127300kit.gifits $949
ORIGINAL: MexGT
need to keep in mind the labor ... its pricey i've heard for cams !
ORIGINAL: Mustang3GT07
I dont need to worry about the price for labor because my uncle is going to do it for free in his own shop so no worry about the labor cost. How does the kit from brenspeed look? Is it good?
ORIGINAL: MexGT
You would be better off stroking your motor and having your uncle do that. It's about the same labor and you get more net gains. Cost would be simliar and the long terms benefits are tremendous with forged internals.
Cams sound awesome in our cars. But most of us don't do it because we want our cars to go fast as well as sound like they are fast.
Don't forget in order to maximize your car you will need to have it custom dyno tuned by someone who knows how to alter cam timing via computer.
