Spark Plugs! Aggggh!
#21
RE: Spark Plugs! Aggggh!
By the time I was done, I can assure you there was quite a bit of penetrating spray in there. Definitely higher than the hex area. However, I am aware of the risk of hydrolocking the motor, so I cranked it over with the plugs out and the coils and injectors unplugged to make sure that I got the majority of crap out of there. I checked the electrode and wirebrushed it thoroughly and still no go. We'll see what happens when I put a new plug in there this afternoon.
#24
I did not change the plug gap on the new plugs. I went with Motorcraft OEM replacements. None of the new plugs have given me problems (as of yet). I would assume that Ford plugs come at the correct gap, especially since (even though I know this is not true)the container says that the gap is not adjustable.
#25
Others may disagree but in my opinion, you don't need to be concerned about gapping at all N/A.
FI is another story and they most definitely need to be gapped IMO. The amount of the gap is dependent on your boost level.
#26
ORIGINAL: modaddict
I'ts been almost a year since I last pulled mine - think I'll do it this weekend. I didn't use antisieze on the electrode cover last time though, only on the threads.
#28
I took mine into dealer 1500 miles before warranty ran out to get dealer to change. The service advisor asked why I wanted them changed? I explained, and he said he would, but he thought it was a waste of money to change that early, and he said they change them all of the time and dont have any problem. I asked him if I waited and some got stuck in head, would
ford stand behind any repair, and he said yes, as long as I had not changed the plugs before (used incorrect plugs, etc).
I have decided to take in and get a modified 60,000 mile checkup this week and will go ahead and get them changed.
I am buying an extended warranty for another 48,000 miles for $2700. before you howl, my boss is paying all but $400 of it, so I figure its a good deal. ($0 deductible)
#29
ORIGINAL: MartyMoose
It's been almost a year since I last pulled mine - think I'll do it this weekend. I didn't use antisieze on the electrode cover last time though, only on the threads.
Before you ask - I run C16 - that's why...
My new build is being tuned for 104 specifically because I am sick and tired of shelling out the money on plugs. I'll have more than enough power this build where I don't have to squeeze every drop of timing I can get so I am looking forward to having one set of plugs last for a minute...
Want to know something really cool??? LOL
I'm looking into being able to run old style plugs in these heads. I'll make a post when I get all the info...
