Tune going bad
Tune going bad
I have a 93 octane tune from brenspeed with 95mmC&L. It is getting noticeably worse with time. When i first got it was great. Now it goes from semi sluggish at below 3 grand to very peppy right after 3 grand. Under steady accelleration you woudl think i feather the clutch or hit the gas down. Is anyone else falling into this? Maybe this is to be expected.
My old cars computer had a learning curve (WRX), is this computer the same way?
Maybe it is because it goes between 40 degrees and 70 degrees from night to day?
Should i see about getting new tunes from brenspeed?
cheers
cheers
RE: Tune going bad
Maybe your just getting accustomed to the power.
Surge may be whenthe CMCV blades open up.
I thought I could feel it with the stock 3.31:1 gear.
I just received my CMCV deletes from Brenspeed today.
RE: Tune going bad
I've posted about this before. The motor makes a very noticeable transistion at 3000 rpms and I do believe it's the CMCV plates fully opening. It's most obvious if you hold part throttle through that particular rev range. It's a little annoying because it isn't very smooth. It reminds me of my wife's old Honda Prelude with the 2.2L VTEC motor.
RE: Tune going bad
Getting worse over time sounds like the adaptive learning thing about the throttle needs to be reset. It's not clear which tunes - if any - can completely disable this function.
There are at least a couple of threads with instructions on how to do this, so try a search on "throttle reset" or similar words/phrase.
Norm
Norm
RE: Tune going bad
I thought this was happening to me as well- but I think we were both just getting used to the tune. In my case, I contacted Doug from BAMAchips about it, and he told me that the Adaptive learning feature is turned OFF with his tunes. I cannot tell u if Brenspeed is the same.
But, I will tell you this though, I had Doug e-mail me a new tune a few days agofor my Emissions test (NYS- needs to be done on saturday); I loaded the tune last night, and you have no IDEA how sluggish the car feels with basically similiar timing to stock. The car feels SLOW- cant wait till I put the 93 tune back in.
Note: the emissions tune was done so that I didnt have to switch to the stock air box, and still had adjustments for my 3.73's. Doug @ BAMA is the man- now lets see if I pass lol.
RE: Tune going bad
In the mornings my car was sluggish from 3000-4000 then after 4000 it was fine after a few minutes of driving it went away. I cleaned the MAF but that didn't do anything. I then cleaned my throttle body and the sluggish went away.
