A/F Guage Install Question
I have hooked up my wideband A/F guage and wired the keyed power wire to a fuse point in the fuse panel. The fused source does turn on with the key but like the radio doesnt turn off with the ignition or until the door opens. Is there a fuse space that turns completly off and doesnt stay on in acc mode or until the door opens? Or will this be ok and not burn the O2 sensor up by being on when the car isnt running?
RE: A/F Guage Install Question
ORIGINAL: killbee
[IMG]local://upfiles/42257/B8F44441A8BD4E5A9C4C3CC0291A5B72.jpg[/IMG]
ORIGINAL: hammeron
hey nine....i thought my pic was the
worst ever until i saw those ^^^^
for some reason, the sjb does not
like to be photographed!
hey killbee, yes one slot for original fuse, one
for the new circuit....not sure which is which...
ORIGINAL: killbee
Thanks for the pics they are a big help. I used the same type of tap.It has 2 fuse slots on top.Is one for the original fuse and one for the tapped wire? If it is which one is for the tapped wire? The reason I ask is the guage calls for a 5 amp fuse instead of the 10 amp.
ORIGINAL: hammeron
ORIGINAL: killbee
Lol. You're not kidding. Especially when you're using a crappy camera phone.
Did you have to cut the SJB cover to use that location? I had to notch out a small section so the wire could pass through.
ORIGINAL: hammeron
that fuse cover was such a PITA to get off, that
i never put it back on!
i will someday.....and at that point, yeah i'll
have to make a little notch....
ORIGINAL: nineinchnail1024
