Problem with rpm's
Problem with rpm's
I noticed while driving tonight when I let off the gas and was coasting I looked at the tach and the rpm's was bouncing between 800 and 1100 rpm. I gave it some gas no miss , it ran as normal, I pulled it in the garage and it idled okay. I did notice the other day at a red light the rpm's were flucturating some. I cleaned my throttle body a couple of days ago it looked real clean didn't see any dirt come out at all. No codes at all, do you think my throttle body is going bad ?
RE: Problem with rpm's
Thanks for the reply; another quick question when I sit and idle for a couple of minutes the car starts to run real rough as though the plugs are loading up, I give itsome gas and its fine for awhile ,it just started doing this recently. How long do plugs last when FI ?
ORIGINAL: AmericanMuscle4.6GT
clean out the throttle body. get some CRC or STP t/b cleaner, spray it out, wipe it out, and i'll be fine.
Anyway, you should have changed plugs when you did the s/c install so they should be fine. If you didnt change the plugs, i would change them now to a colder heat range and see if that fixes your problems. I am suprised they have lasted this long if they are the stock plugs
ORIGINAL: howarmat
You didnt learn how to read in school did you
ORIGINAL: cfr865
Thanks for the reply; another quick question when I sit and idle for a couple of minutes the car starts to run real rough as though the plugs are loading up, I give it some gas and its fine for awhile ,it just started doing this recently. How long do plugs last when FI ?
Omgitsa88Stang
10-05-2015 07:33 AM
musnicki
09-23-2015 07:11 AM
panic
09-10-2015 05:56 PM
zanemoseley
09-06-2015 12:58 PM
