launch question
Old Apr 6, 2008 | 02:33 PM
stealth_GT's Avatar
stealth_GT
Default launch question
aside from tires,what suspension mods are nessessary to get the most traction and hardest launch with a basic auto power set up?
(gears;3:90s/4:10s,torque converter,aluminum driveshaft,intake/tuner)
trying to cut some mean 60fts. and run hard in the 1/8th.
Old Apr 6, 2008 | 04:50 PM
cobra443's Avatar
cobra443
Default RE: launch question
Lower Control Arms (LCA's) is all you really need to basic power levels if you dont want to spend much money. Also depends if your lowered or not.
Old Apr 7, 2008 | 08:46 AM
06VistaBlueGT's Avatar
06VistaBlueGT
Yep LCA's (adjustable if you're lowered, non-adjustable if you're not) and some LCA relocation brackets and set the LCA's to the lowest setting on the braket, that should give you a good launch.
Old Apr 7, 2008 | 12:11 PM
modaddict's Avatar
modaddict
***** Best?
Upper adj. and Lower Ca's
TC with good stall
Coilovers
Panhard Bar
Extreme Anti Roll bar
Tru Trak
Good Rubber
With the right power = 1.4's 60's easily...
Dokilar
15
Oct 16, 2015 08:13 PM
TCStangerv6
Oct 11, 2015 05:57 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
