am i getting the run around from the dealership
okay dropped my 07 mustang off at dealership(yesterday) for possible cam phaser replacement and timing chain tensioner replacement due to some slight knock (hardly can hear it) and some swishing noises at idle. i called the dealership today and they told me that nothing appears to be wrong and everything checks out normal, timing is correct, cam phasers are good, etc. they told me that the newly ford tsb told them that i shouldnt be running a fram oil filter due to it not being the right one to use cause ford uses a specialy vented oil filter for our car(when i bought my car to them to schedule an appointment that was one of the first thing the mechanic said was that i had the wrong filter on my car). does this sound right to you guys. they said it was something new..they also said to drive if for a month and if the sound is still there theyll do a major teardown. i talked to the guy who writes down the info when you first drive up to the service dept. and he was relaying info that the mechanic was telling him. they were in the process of changing the oil at the time. i mean if they were trying to screw me why would they tell me to come back in a month if i still have thesame noisesinstead of fixing it now while they have the car there. car has 9,640 miles.
RE: am i getting the run around from the dealership
Well an engine tear down under warranty is expensive. It just cost me nearly $1000 in labor to get a cam tension replaced in a 4-cyl Audi... I don't want to know how long it will take them with our cars. The thought I am sure is that right now they would be replacing a couple parts, but if you screw up the entire motor then they only have to do that one thing...
It's pretty much what my extended warranty company said they would rather do. It's more cost effective for them to replace a $4000 motor than replace $6000 worth of parts here and there... I am sure this is the same thing they are looking at.
You know you can always bring it to another dealer.
Im suprised theyre even willing to work with you w/ that driveshaft. I'm not sure if theyre trying to pull anything but they gotta be half way decent if they'll still honor the warranty with that. I bring my car to the dealer w/ my mods on too but a driveshaft? IMPRESSIVE.
why the hell would the driveshaft matter
The cam phaser thing might be fine....there are tons of noises that are normal for the car so you might be hearing things that are normal
as for the filter, that sounds fishy to me.....but then again i wouldnt use a fram anyway
ORIGINAL: ericmuscle
For example K&N is barelyequivalent on the S197 to OEM. K&N used to better than OEM. To be better you have to go with an intake AND tune these days.
If the dealer points out the Fram filter, you have two three choices,
1) Comply until you get your issues resolved and use Motorcraft filters
2) Go to another dealership and see what they say
3) Stick with Fram and this dealership and hope that if they do find a problem they can't blame the filter. Oil is the engines lifeblood. Any problems found that could be affected by internal lubrication puts in to question every component in the oils path, including the filter. Keep that in mind.
They say there's a TSB that says you shouldn't be running a Fram filter? I'd find out the TSB #. But I agree with Howarmat. I wouldn't run a Fram filter on my Stang (but I've used them for years and still do on my SUV so everyone, shutup).
i got back from the dealer and they changed the oil and stated the fram oil filter doesnt have a vent that allows for the oil to reach the top of the valve train due to lack of pressure build up, which could equal noise and knocks from decrease oil saturation. the mechanic was pretty persistant aboutneeding touse the motorcraft oil filters. they told me if i have anymore problems with noise to bring it back in a month and theyll do a complete tear down. i played stupid and asked can i buythe oil filtershere just to see if he was just trying to get me to come to them and buy em and have my oil changedand he said you can get at walmart to save some money. anyways the slight knock is gone at idle but i do still hear a rhythmic swishing noise at idle when standing and having my head next to the grill on the car. do any of you have the same sound. little noises like these drive me crazy can ANY of you guys tell me that this swishing noise is normal. can you check on your cars. ive only listened to it after my car was @ operating temp.
Here's a previous post about filters.
https://mustangforums.com/m_4562978/tm.htm
Someone had posted a link to a site that tested a bunch of filters
http://home.mindspring.com/~cewhite3nc/id15.html
Didn't have good things to say about the Fram...
