HELP - diagnose slippage when down shifting
Sometimes, not all the time, on freeway when I down shift from 5 to 3, or 5 to 4, the throttle is not responsive, almost like it slips, and then it comes on. It is like a quiet stuttering of the engine before it kicks in to WOT.
Anyone else experience this? Could be the clutch? What else. Only happens sometimes.
So at 65 mph, down shift, car doesn't immediately hit WOT and pull, but quiets up (engine is not as loud at this point) with slight acceleration then grabs andthe the WOT kicks in.
Help.
Help.
ORIGINAL: v8pilot
You might be slipping and traction control kicks in. Press the TCS button so the light turns on. which disables the traction control system
Thank you.
ORIGINAL: crazystylin
Thank you, good advice. I turned the TCS off, and it solved the issue.
Thank you.
ORIGINAL: v8pilot
Thank you.
ORIGINAL: A_J
Slipping on a downshift.. are you rev-matching?
Thank you.
ORIGINAL: v8pilot
Thank you.
