Torq on lugnuts?
04-26-2008, 05:43 PM
Torq on lugnuts?
Whats the torq specs on the wheels for are cars?
04-26-2008, 06:31 PM
RE: Torq on lugnuts?
service manual says 98 ft-lbs
haynes manual say 100 ft-lbs
04-26-2008, 11:11 PM
just did this today.........100 FT pounds (per the owners manual).
04-26-2008, 11:16 PM
In an emergency and for future reference,Every car I have ever seen with aluminum wheels from the factory is 100 ft lbs.I'm sure that there are some with different specs but this is what I have observed.
04-27-2008, 09:46 PM
Owner's manual FTW!!!
100 ft/lbs.
04-27-2008, 10:53 PM
Do you actually have to torque them to 100lb? I just tighten them until they are tight enough!
Hell I didn't even use a torque wrench to torque down the manifolds bolts after my cmdps install.
I should be fine, right?
04-29-2008, 03:49 PM
I use a torque wrench to achieve the exact torque of 100FT pounds. Also, torque in the star pattern.This providespeace of mind for me.
04-29-2008, 04:47 PM
I also don't use a torque wrench for the lug nuts. I just go in a star pattern until they are tight.
04-29-2008, 04:53 PM
using a torque wrench, will keep
us from over torquing
04-30-2008, 01:54 AM
Quote:
ORIGINAL: hammeron
Hi hammeron,
And brake vibration.
HTH!
