Blew the motor today!
#23
RE: Blew the motor today!
man i am playing with the a grenade also...At WOT on the top end i am at 12 lb of boost at 4700 elevation. Mine sits at 10lbs until i think about 5k and then it goes to 12lbs of boost. My tune is by JDM. They emailed me my tune and once installed i sent to texas hotrod and had them dyno it to see if we were close. It needed adjustment and so THR and JDM talked about the adjustments and the sent a second tune that corrected the areas which needed correcting. Hope mine holds up betting so i do not blow it too quickly.
#24
Tune was spot on as far as Brent said at brenspeed and my air fuel was 12.0-12.2,
You should be at 11.5 - 11.6 tops on your air/fuel. If you had 12.0- 12.2 A/F that is way lean for pushing 12 PSI.
What kind of gas were you running?
Brent tuned my car and it is at 11.5 across all RPMs at WOT - I am compl;etely surprised he would say that an A/F of 12.2 was "spot on"
Only a fool would run 12 PSI on a stock block without a custom dyno tune. How dou you run 12 pounds of boost and only turn 12.5 quarte-mile times?
#26
Sorry to hear about your motor!...I defitnetly could be next...I am at 12.7 A/F running almost 13psi Dynoed at 525 rwhp. I have no problems todate and i have been getting on it....
#29
hmmm glad I read this thread!! I'm on a "stock" KB pulley at 10.5psi of boost with approx 11.5 A/F @4900rpm. I was thinking of going down a notch to a smaller pulley. No sir-eee!!! I want my stock lower end for a "just in case" scenario.
Sorry for the luck man...sounds to me like you almost "wanted" it to happen for that forged bottom end!
#30
Well, actually that comment was for the guy (hotairgypsy) running 12.5 on a Saleen with 12 PSI and a canned tune.
Since you hade a dyno tune I would have expected a safer A/F than 12.2 though.
93 octane gas is not sufficent for 12 PSI either!
