Finally dynoed the whipple HO.
RE: Finally dynoed the whipple HO.
Great numbers. Where did you go for the tune?
We were at No Problem friday, you could cut the air with a knife. Look forward to seeing you at the track soon.
Humidity in this area is often 100%
ORIGINAL: forensicsteve
I'm sure I'll run into you at NPR eventually. I just hope I don't end up next to you so I get shown up on my youtube vids, lol.
I think in another thread it was one of the last of the first generation whipples? Nine -quick question what degree timing is your tune at now? Just curious ... I have the first gen whipple and running about 10.7 boost and 11.5 A/F at WOT and at 6000 rpms I was at 10.9 (pig rich) yeilding 454 RWHP in 93 degree heat and 60+ humidity in september. I had to get it retuned because of sputter on startup (only while cold) and the dyno at 69 degrees and 30% humidity yeilded 465 RWHP and the torque stayed the same at 440 RWTQ. I attribute that to the heavy 20's and the totally stock driveline. This year is the year of supproting mods like the 8-rib belt kit and thumper tensioner, one piece DS, new motor mounts and McLeod twin disk....than back to the dyno and she what happens.... (hopefully no "boom"[&:]) J
ORIGINAL: moosestang
Did you get the second generation whipple?
These are on my short list as well..
ORIGINAL: mygt500
ORIGINAL: mygt500
ORIGINAL: nineinchnail1024
I'm also interested in the Thumper tensioner. I saw a picture of it on another forum and it is beautiful. Where can I buy it??
Maybe we should try to get a group buy on the ST, or Thumper tensioners, I will go in on it. I am sure with all the Whipple's going in lately we could get quite a few. Any interest?
ORIGINAL: MustangGT0405
I am pretty sure Adam at ST makes one too. CK recommended it, said it was a little cheaper as well.
