Installed Pypes o/r h
RE: Installed Pypes o/r h
ORIGINAL: Agleon
How can you tell if you have a leak?
ORIGINAL: unlawfl
Mine leaks where the OR/H is bolted to the passenger exhaust manifold. I tried to fix but I think the original mold from Pypes was worn when stamped. I will haveto heat up and rap it to stop the leak. You may have this problem so carefully reach between the frame and exhaust manifold to check the joint area when vehicle isrunning. Don't burn yourself but if it leaks you will feel the excaping air. I am at a loss and Pypes will not return my email questions.
I didn't get any new bolts and ended up using the old ones. Now I have a broken bolt thats pretty much froze/heat-welded in the collector flange. I've had issues with these pipes ever since I put them in. I welded the H joint together to save the trouble of leaks...not that that helped much. I had bad exhaust leaks from the get go. I'm putting the stock catted pipes back on when I can get that broken bolt out. PB Blaster hasn't been much help...
ORIGINAL: Raven27
Actually yes this was one of the problems I encountered. The flange on the down pipe was bottoming out on the exhaust manifold bolt stop before the pipe made a tight connection. I had this problem on both the passenger and drivers sides. I just took a large diameter drill bit to make an inset on the tops of the flanges so the flange would allow the pipes to make a tight fit to the exhaust manifold.
ORIGINAL: unlawfl
i had the same trouble, and my friend's shop said they did something similar to this fix. when you have time, can you supply pics, or diagrams of this fix so i can understand it better?? the reason is that i think i'm still getting a leak at the collector and would like to explain better how to fix it. thanks!!
ORIGINAL: harraid5711
ORIGINAL: Raven27
ORIGINAL: unlawfl
The plot thickens....
Here are some pics of what I was talking about by making a countersink in the flang. This is the side that rest on the stops of the exhaust manifold bolts. You can use a dremel to make the countersink.
