Mustang SLP Catted X-Pipe: Will it pass emissions?
Old Apr 29, 2008 | 07:44 PM
red96v6's Avatar
red96v6
Default Mustang SLP Catted X-Pipe: Will it pass emissions?
Im looking into getting the slp x-pipe with high flow cats and I live in Texas so i have to pass emissions tests. Will the high flow cats pass? I have heard they wont... Also, with slp axle-backs, will it be much louder? I had an off road h-pipe, but it was a little too loud. I need something slightly more tame. Will the high flow cats make a big sound difference over the stock ones?
Old Apr 29, 2008 | 08:15 PM
brad281's Avatar
brad281
Default RE: Mustang SLP Catted X-Pipe: Will it pass emissions?
Slp loudmouths and a x pipe will be louder for sure. Especially if you were to go offroad. Which it looks like you don't want to. Not sure that the loudmouths would sound good with an x,jmo.
I wouldn't count on high flow cats being louder than stock ones we have. You said you already had an o/r h? How often are your emission tests on a new vehicle? might want to just go offroad h or x and switch up a little before its time.
Old Apr 29, 2008 | 08:25 PM
desslok40's Avatar
desslok40
I have the SLP catted X pipe, in AZ don't need emissions testing for 5 years on new cars but I can tell you this, The car definately emits more fumes, you can smell it !![:'(] If emissions testing is an issue I would go with a X pipe that retains the stock CATs, I got long tubes so I couldn't do that but if just adding an X-pipe I wouldget one that works with the stock CATs, I believe Hooker makes one, not sure who else.
Old Apr 29, 2008 | 08:41 PM
VistaGT's Avatar
VistaGT
There is a diff. in sound, def. noticeable w/ high flows cats. I ran the catted X w/ no muffler(loudmouths) for a little and really liked it. LOud but in a good way. Not obnoxious like the O/R pipe which I too thought it was too loud and took mine off. The catted X is a nice medium and depending on what A/B can be quite loud. If, as is this case it's the loudmouths it will sound a lot louder than stock. Not sure if it will pass emissions though-you can see right through the cats. May I suggest bassani? I had the catted bassani X. 1. It's got a better crossover. 2. It's got the highest flowing cats. 3. It's a good amount cheaper than SLP.
Old Apr 30, 2008 | 02:49 AM
smokestang's Avatar
smokestang
If its any help i had a frpp x pipe ,just a bolt on kind that uses the factory cats& can say they do nothing for volume, just tone! I recently got the bassani catted X andwow what a difference much, much louder , but not as bad as an O/R pipe! totally worth the money IMOas for inspection ... if your state does the sniffer test you wont pass w/ high flows
Old Apr 30, 2008 | 09:22 AM
Norm Peterson's Avatar
Norm Peterson
ORIGINAL: smokestang
Any particular reason that they shouldn't other than maybe the cats not being OE and the car is still within its original emissions warranty period? Other than that, all I'm aware of is that aftermarket cats need only last 25,000 miles instead of 50,000.
Norm
Old Apr 30, 2008 | 09:50 AM
subzero05's Avatar
subzero05
IF your testing is along the same lines as California then no you will not pass. The substrate that is used in the aftermarket cats is different than the O.E substrates that came on the car. Some of them are OBD II compliant and you MAY pass , but even then its still likely you will not because of the "honeycomb" used. Plus, you definately won't pass a visual if they do those in your state..I've been down this road..Now , I have a "friend"....
Old Apr 30, 2008 | 11:59 AM
smokestang's Avatar
smokestang
Aftermarket cats dont do much for pollution asthe OEM ones do ...magnaflow claims to be OBDII compliant ,so they could possibly pass a sniffer test it all depends on the standards of your states inspection. Id just put the factory pipe back on when that time comes, then switch back!
richard1027
Sep 8, 2015 01:24 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
mweiland
Aug 13, 2015 05:11 PM
daytooday
Aug 11, 2015 09:22 AM
