Poeple with Hurst shifter
Hey guys,
Just had the dealer install a Hurst short throw. When comparing it to the Hurst shifter in a Shelby GT I tried, mine is much stiffer and takes more effort to get into gear. Also under hard excelleration, the 3-4 shift doesn't want to go usually very smoothly if at all. Granted the shifter is only a week old but do I need to have it adjusted or is this part of the "break in" period.
The stock shifter hardno problem going 3-4, I missed a couple 1-2 and 2-3 but never 3-4.
Do I need to get a CHE brace with torque limiters or solid bullet motor mounts?
Thanks
UrS4
Thanks
UrS4
RE: Poeple with Hurst shifter
I have the hurst, it just takes some time to get used to. There may be a break in period but nothing substantial. I also have bullet motor mounts, unfortunatley what I dont have is the motivation to install them. But as far as your question is concerned it will most likely just take a while to find the sweet spot.
You can probably take another shifter (like the MGW) and swap the stick-n-ball with the hurst to have best of both worlds. That's what I would do...but of course I have an auto so...
ORIGINAL: SirKnightTG
