Need a STRONG replacement battery.
Old 05-04-2008, 08:12 PM
Bmr4life
Bmr4life's Avatar
Default Need a STRONG replacement battery.
Anyone know if the Optima yellow tops fit without modifications?
Which yellow top fits without modifications?
Bmr4life is offline
Old 05-04-2008, 08:18 PM
07BOSSGT_S197
07BOSSGT_S197's Avatar
Default RE: Need a STRONG replacement battery.
I have one. Works awesome! go for it!
07BOSSGT_S197 is offline
Old 05-04-2008, 08:45 PM
Larmo
Larmo's Avatar
yellow top or red top?
Larmo is offline
Old 05-04-2008, 09:01 PM
Stkjock
Retired Mod
Stkjock's Avatar
optimum yellow if you have a lot of electronics (deep cycle)
Red Top for cranking!
Stkjock is offline
Old 05-04-2008, 09:02 PM
Bmr4life
Bmr4life's Avatar
Bmr4life is offline
Old 05-05-2008, 12:42 AM
chp2150
chp2150's Avatar
Isn't $185 for a battery a bit much? Are they really that much better than some of the other high quality batteries available?
chp2150 is offline
Old 05-05-2008, 07:39 AM
tn_gt
tn_gt's Avatar
yes!!! the deep cell batteries are amazing, but yea like stkjock said yellow for electronics like a system of tvs or something, and red has the cranking power to start it up with easy...or if you go with a cheaper battery try always turning your ac/heat and radio off before you turn the engine off, or at least before you start it back up...you would be surprised how much easier it is on battery when you do this, especially the cheap batteries they put in these things lol
tn_gt is offline
Old 05-05-2008, 08:40 AM
BoidMorphs
BoidMorphs's Avatar
I've had my original battery for over 2 years and 39,000 miles now with no problems. I believe the battery that comes with a vert is more heavy duty to handle the roof going up and down. I'm thinking whatever came stock in my '06 would do very well in a coupe.
BoidMorphs is offline
Old 05-05-2008, 10:13 AM
Nuke
Nuke's Avatar
Although the Yellowtop is a deep cycle/cranking combo, unless you're running electronics with the engine NOT running for any length of time, the deep cycleaspect is a waste of money. When the engine is running, your alternator should be able to provide whatever power you need with anything beyond the alternator's capacity coming from the battery, which shouldn't be much and SHOULD only be short duration. IF you're pulling that much power from your stock alternator, you should buy a HO alternator.
Nuke is offline
Old 05-05-2008, 10:39 AM
08Bullitt215
08Bullitt215's Avatar
isnt the red top still better than any other regular battery? i have a red top in my 66 mustang with a 302 and it starts up faster and betterthen my 08BULLITT
ive also heard with the optima batteries that you can drain them dead and put them on a battery charger over night and they'll be evenstronger then they were before
08Bullitt215 is offline
Quick Reply: Need a STRONG replacement battery.
