Free Clutch Installation
So here's the deal.. I've been having a weird shuddering problem that comes and goes when i engage the clutch in 1st mostly... its like when I hit that point where the clutch grabs and begins to catch power, the car shudders, violently sometimes, and it's a very bad vibration/hopping feeling... Well I talked to my service guy who I've known for a long time, he told me it sounds like a bad pressure plate. They're going to replace it under warranty, and he was telling me that since they're already going to be in there, he wouldn't mind throwin in a new clutch disk if I wanted to buy one... Question to you guys is, which clutch should i go with? I keep hearing great things about centerforce and the spec stage 3, but any opinions? Also, do you guys think its a good idea to have them do that, because they're doing it off the record, if I have a problem, I can't bring it to them, but I save mad money in a clutch install, so what are your guys' thoughts? Oh and forgot to add that I'm going to be getting the Saleen 540HP kit put on my car soon by HCM so that's why I'm thinking it's a perfect time to get this done..
RE: Free Clutch Installation
Get the mcleod RST twin disc! Great for any FI and very streetable stock like pedal feel and good for 900 ft/lbs TQ! But the above mentioned are great too and I have heard good and bad about spec but mostly with the spec stg 2. hope it helps and if you get the clutch and pressure plate new/fixed I dont think you will have any warranty issues with that area even after the S/C!
the stock clutch should definately not shudder like you describe. My spec stage 2 doesn't even do that.
So far my spec stage 2 with spec steel flywheels is working great. It has an on/off feel to it, but it's still very easy to drive with it
Pedal pressure is the same as stock.
Would you guys suggest getting an aftermarket flywheel as well? I'll be putting down 465 to the wheels, but thats not a ridiculous number to the point where like an aluminum flywheel would be needed right? But yea I definitely have been hearing a lot of great things about the McLeod, probably gonna get that. No reason to cheap out on something that can put you out of commission real quick..
ORIGINAL: xxDerek
I'm likin the look of that fidanza and the price as well. i don't want to cheap out on a clutch, but the McLeod is VERY pricey... so here is probably a stupid question but since they are replacing the pressure plate under warranty, would it be okay to use the stock pressure plate with like the fidanza disc and flywheel, or do you have to use their ( or any companies kit ) pressure plate along with the other components to match up? I'm new to this stuff so hey don't be to hard on me
