Hot Rod vs. NSR
RE: Hot Rod vs. NSR
I recommended stage 2 comps to saleen only because they have a nice idle and comp told me that they were the best for supercharging applications (most hp gains). But like earlier stated, he is in it for the sound.
SirKnight, those cams though in the white S197 still sound rediculous for hot rod cams. That sounds like a car with BBR stage 2 or stage 3 comps... which springs are high recommended. But I probably shouldnt judge based off of sound.
RE: Hot Rod vs. NSR
RE: Hot Rod vs. NSR
I still can't find Stage 3 comp cam video clips for the S197. I find them for the older mustangs. I want to hear what the stage 3 comps that Brenspeed sells sounds like. I already know what kind of power gains to expect. Brenspeed has a pretty nice article on that.
I have heard some bad things about BBR cams so I don't know. When I asked the guys at Brenspeed about them, they didn't seem to excited about them either. There's a reason why they only carry comps. I also would NEVER use re-grinds. I've heard about the material added to re-grinds wear off over time and ruin your valvetrain and possibly more. They're cheaper for a reason.
IMO, Comp Cams are the only cams anyone should consider at this current time for the S197. I was interested in what Crane cams has but there's no info about them to make a good informed decision. Comp cams are quality though for sure.
Check this page out: http://www.compcams.com/3valve/
They have some pretty exciting looking grinds on there. I really like the XFI SPR models. Sure those require more work and tuning, but it looks like they would have the best idle sound and best performance.
RE: Hot Rod vs. NSR
Looking at the dyno chart on that page, the XFI SPR stage 2 is the way to go. You don't lose any power at the low end like you do with NSR and VSR but gain a lot more than those two on the high end. Nice.
Hmm, somehow Jim D'Amore reports a 72 rwhp gain on a NA engine and comps. I wonder if he used the stage 3 XFI SPR, which unfortunately do not show on their dyno chart.
RE: Hot Rod vs. NSR
I will be getting the hot rod cams here shortly. If I get the same sound as the white mustang I will be so stoked!!! Not really getting cams for performance, mostly a sound mod. Call mesilly but nothing compares to that lopy idle ,...not evenhp.. but I am also s/c so yeah...nuff said..
RE: Hot Rod vs. NSR
SirKinight, I swear I have seen stage 3 comps on youtube. Again, on a restricted server but at work I will look it up. It was a red S197 and the guy shows before and after video clips of his exhaust.
And I agree with you to an extent. Comp is good. I am considering being one of the test subjects however for another company. Im going to wait for Sutton to release their results.
RE: Hot Rod vs. NSR
Comp stage III cams:
http://media.putfile.com/Comp-Stage-3-cams
That's with BBK headers, Bassani catted x-pipe, and Mac muffler. I now have JBA longtubes and off road h-pipe (same Macs) but never got around to making a video yet...
John
John
RE: Hot Rod vs. NSR
That sounds pretty sweet. Are those the same stage 3 comps that Brenspeed sells?
I'm starting to get confused now. What brenspeed is calling stage 3 is actually stage 2 according to Comp Camps (see the comp cams 3-valve link above). I checked and the part number (127300) and grind numbers (XE261H-15) match. Well mostly, the cams on comp's site says -15.5.
Also, the "stage 3" from the above video sounds a lot more lopey than what I see on youtube called stage 4. I have no idea what the stage 4 is since comp cams does not mention that.
I'm going to send Brenspeed an email about this stage number thing.
RE: Hot Rod vs. NSR
I was at the world street challenge today and stoped by the Ford Racing both and asked what kind of power gains to expect with the hotrod cams and he said on their N/A car they gained 40 rwhp.
