Hurst Shifter install problem???
Old May 17, 2008 | 02:42 PM
UrS4's Avatar
UrS4
Default Hurst Shifter install problem???
Hi guys,
I had the dealer install my hurst shifter a couple of weeks ago. The shifting was very stiff the first couple of days and very notchy. Nothing like the smooth fast shifting of the hurst lin the shelby GT.
Well I thought it was a break in thing so I gave it a couple weeks.
Now the shifter rattles sometimes under mod acceleration. And the worst thing is under 1/2 to 3/4 throttle in 3rd the shifter will not go into 4th, it takes another second while the motor spins down and I jam it into 4th. Under light acceleration it slides into 4th fine if not a little notchy still. Overall the shifts have loosened up a bit but it is still notchy. Also I noticed when the shifter is in 1st, 2nd, and 5th the shifter handle has very little side to side play, but it 3rd and 4th gear it can move side to side about an inch.
So is there anything that can be done? Is there some bushings that weren't transferred to the hurst shifter? Is something loose underneath causing the rattle? Does anyone have or know of specific install instructions with pics so I can fix this? I don't want to go back to the dealer since if it was installed incorrectly why go back.
Old May 17, 2008 | 08:18 PM
moosestang's Avatar
moosestang
Default RE: Hurst Shifter install problem???
This is one of those installs that I recommend, everyone with a driveway, doing themselves. I'm sure there are some online instructions somewhere, but it's not that complicated and i'm sure you will know if something is not right with the install. My hurst has always been notchy, I don't see why the shelby would be any different.
Old May 17, 2008 | 08:42 PM
howarmat's Avatar
howarmat
s197 Junkie
have you checked the stickies.....i know there is one in there
And there are atleast 4 that i know of on the net so google for others if that one isnt enough
Old May 17, 2008 | 09:28 PM
07musclemustang's Avatar
07musclemustang
Is your shift arm very tight to the left drivers side???? if so you need to rotate the pivot a 180 and re bolt it.
Old May 18, 2008 | 12:20 AM
jdback19's Avatar
jdback19
Loosen the shift arm up and go back with lock tight but dont tighten too much. And the rattling is probaly like on my shifter its the damn shift ball put a t-handle or pistol grip on it.
Old May 18, 2008 | 10:15 AM
UrS4's Avatar
UrS4
No the shift arm is in the middle.
Old May 18, 2008 | 10:16 AM
UrS4's Avatar
UrS4
The rattle will happen even if I have my hand on the shifter holding it, so I don't think it is the shift ball.
Old May 18, 2008 | 10:17 AM
UrS4's Avatar
UrS4
Thanks, I will check the stickies.
Old May 18, 2008 | 11:43 AM
jdback19's Avatar
jdback19
ORIGINAL: UrS4
Yeah so did mine its inside the ball or something. I put a pistol grip on it an the rattle went away.
Old May 18, 2008 | 10:44 PM
pat123's Avatar
pat123
Mine is new but was installed by a custom shop; I am not having any problems other than it has been ten years since I have driven a standard everyday.
djbigskrilla
Sep 20, 2022 01:04 AM
Urambo Tauro
Dec 17, 2016 03:30 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
5.0pntydrpr
Aug 27, 2015 10:26 PM
jjwinel78
Aug 17, 2015 03:34 PM
