MF'er I got a code already: P0191
Well I just got my car back today from having upgrades done. Heres what I had installed:
Saleen SC, GT500 fuel pump, 60lb injectors, Saleen Ultimate air kit, gapped HTOs, 3.2 pulley, v10 water pump pulley, Gates belt, line kit, XCal with JDM tune
The car ran awesome on my way home. Throttle response was unbelievable. I get home and about 2 hrs later I go to take my dad for a ride and the car sounds different when it starts. The car sounds "boggy and muffled". I pull out of the driveway and the car has horrible throttle response and I notice a yellow light is now on, so I turn around and park the car. I hook up my XCal and I get this code: P0191 S CIR RNG PER
I'll be calling JDM and the install shop tomorrow. Do you guys have any suggestions?
RE: MF'er I got a code already: P0191
That sounds bad.. 0191 is Fuel Rail Pressure Sensor Circuit Range/Performance
From http://autorepair.about.com/cs/troub...l/bl_obd_1.htm
Google is your friend.
http://tinyurl.com/4jawje
Thats what I found on look up thru google..... hope it helps....could be one of many things
vapor lock....low fuel pressure....high fuel pressure....low fuel......vacuum leak.....or bad fuel rail regulator sensor....
If the car is low on gas.....fill it up.....and check all vacuum hoses. If no improvement go back to where it was installed....sounds like something popped off or a sensor went bad or is loose.....since the install was just done and it ran fine but now it is not something may have come loose! Hope it helps
Well I cleared the code and took the car up the road. The throttle response is back and the code didnt come back on. Should I take it back to have them inspct it or wait to see if the code comes back again?
I think I would call the shop and atleast let them know what happened. I'd let them know that so far its working and then you can either 1) ask them to look for a problem that doesn't currently exist or 2) wait till it happens again. or 3) they may have an idea what caused the problem because they've seen it before.
I spoke with the guys at Fastlane and Jim III at JDM. I have checked all the connections and fuses that would apply to the fuel system and they all look good. I just got back from taking the car up the road for the 2nd time after I cleared the code and it still hasnt came back. I will be dropping the car back off at Fastlane on my way to the beach in a week or so so they can recheck the car and re dyno it to see if anythings off. I was told, by Jim III at JDM, if the psi goes 6 points above or below the set point it will throw "that" code.Whywas itidleing so bad yesterday afternoon and had horrible throttle response and today it seems much better?
Maybe something as simple as vapor lock after the new pumps were installed? It threw the code and has since corrected itself.....hopefully it was something simple and since you looked at the fuses and the wiring and they appear fine and all hoses are connected the problem may have been just that simple....let us know what happens....later
ORIGINAL: mygt500
Ive taken the car up the road 3 different times today and the code hasnt come back. Im dropping the car off at Fastlane on my way to the beach in a couple of weeks. They said they would be more than happy to look at the car for any problems. I may go ahead and get a custom tune while its there.
