N2O On Barricade
RE: NO2 On Barricade
Dont know about cheapest but Brenspeed has all the stuff. Plus I think if you get the tune from them too, they will update for free as you mod the car.
Keep the nitrous kit connected too whenyou get the blower. Run a 50 shot at first. I want to try this down the road
I will, but I will build the motor before pushing the blower and nitrous. Thanks for the help
So what ALL do you recommend from this page?
http://www.brenspeed.com/05-08-musta...cessories.html
ORIGINAL: 06Saleen3V
It will be in the south side of Houston, but thanks for the offer [8D]
zex kit with chrome bottle with pressure gauge
remote bottle opener
purge kit
bottle heater
window switch
SOS cup holder switch panel with gauge and switches
got itfor a prettygood pricetoo, thanks again FM
Hello, love the car! I ran theZex nitrous setup last year, then pulled it off this year and put on a supercharger, kinda like what your going to do. The Zex is a great bang for the buck. Definately get the racers kit, it's cheaper buying your accesories this way, and you can always sell whatever you don't use on ebay. By the way, I ended up selling my Zex system on ebay and recouped most of my money, so that's something to think about when your done. For running on the street, your going to need a remote bottle opener, so you don't have pressure against your solenoid all the time. (bad, and if your solenoid leaks..boom) you can run your normal tune, just pull 3 degrees timing out of it yourself. I was running a Bama race tune, and that worked great. Anything above a 75 shot, You definataley want a dyno tune. Run colder plugs, and check often!! I was melting plugs at only a 100 shot, with a nitrous dyno tune. Brenspeed did the tune, they never could figure out why it was doing it. Hence, the supercharger Some guys run a 125 shot with no problems, hopefully you'll be that guy. I ran the Zex window switch, cool unit, definatley helps with traction down low. Don't spray below 2000 rpms....can be very bad, again go boom. Speed of Sound makes some great switch panels for your console, a very clean setup if you go that route. Hope this helps!!
Stacy
Stacy
