knocking sound
Old Jul 18, 2008 | 10:40 AM
Tjeppelin's Avatar
Tjeppelin
Default knocking sound
hey guys just started noticing a knocking sound coming from the engine, you can only notice it at idle. The engine only has 26000 miles on it i know my A/F ratio is right where it shouldbe. Any Ideas? It kinda sounds like a loud tick or a real subtle knock even with your ear next to the valve covers. also there has been no noticalbe loss of power and the engine doesn't run rough at all. Any ideas would be apreciated. Thanks
Old Jul 18, 2008 | 12:06 PM
Kaisoboy's Avatar
Kaisoboy
Default RE: knocking sound
Are you sure your not hearing the injectors? Take a long screw driver and place one end to your ear and the other on the tapit cover (valve cover) and try to isolate the sound and report back.
cheers
Old Jul 18, 2008 | 01:02 PM
blackS197's Avatar
blackS197
The Manual says occasional knock or pinging at idle is normal.
Old Jul 18, 2008 | 01:14 PM
Kaisoboy's Avatar
Kaisoboy
Hmmm...did not know that! Interesting!
Old Jul 18, 2008 | 02:48 PM
super05mustangGT's Avatar
super05mustangGT
It also could be your lash adjusters or your can fallowers. I have had the same problem with mine. I have 30,500 miles on mine. But I have aftermarket cams also.
Old Jul 18, 2008 | 04:15 PM
157dB's Avatar
157dB
Cut & Paste Expert
How old is the oil?
Thin used old oil sometimes causes ticking noises.
Old Jul 18, 2008 | 04:27 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: Tjeppelin
Check your plugs, you could be due for blowing a spark plug out of the head. I've read many people get that ticking/knocking in one particular area just prior to blowing a plug out.
The knock you hear is the spark plug that is backing out or geting weak threads allowing the pressure of the cylinder to leak past it.
Old Jul 19, 2008 | 07:21 PM
wilkinda's Avatar
wilkinda
2010 Section Moderator
ORIGINAL: Derf00
ORIGINAL: Tjeppelin
mine is making the noise worse abopve idle speed and then is fine once I get to idle speed,,, Spark-plug blow-out huh..guess what i am doing tomorrow!!!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
