What gauges should I get?
So my car is already S/Ced, about to put gears in this weekend, then stage 2 blower cams are going in next week. The mech thats putting the cams in said it would be stupid to even drive the car without an air/fuel gauge. So other then the air/fuel gauge what are the next 2 most important gauges to have in a car with my set up? Oil press? Fuel press? Boost?
What if your O2 sensor fails? Fuel pressure, oil temp, water temp, and boost/vacuum are all necessary to run a blower. You need to know all these to prevent a catastrophic failure in your investment. I know these are redundant as hell but I think they are necessary
ORIGINAL: zkiller
wide band is all you realy need.
but thats 5 gauges if you add the air/fuel. So instead of my asking what gauges to get how about you all tell me which gauges you have. Make sure to note if they are mech or elec.
^^^^OK Boost -mech, fuel pressure-electric, and wideband digital A/F..... I have yet to install but plan on getting water temp, oil pressure, and volts!
wideband/boost/aeroforce scangauge.
the aeroforce can give you about 20 different gauges in one by plugging into the obd port and reading what the computer is reading. you could do a double or tripple set up also on the scangauge.
