Help with Hot Rod Cams
I need some help understanding what the Ford Dealer has told me.
I put my car in the shop on Monday before I left on a business trip with the purpose of them installing the following:
FRPP Hot Rod Cams (M-6550-3V)
FRPP 3.73. Gears
Steeda UDP
BBK Polished Ceramic Coated Equal Length Shorty Headers
and a custom tune ordered from Doug at BamaChips
Spoke with the dealer Tuesday afternoon late and they said it was complete but that they felt the car/engine did not seem balanced. They indicated that they had been in contact with Ford (or Ford Racing - not sure which) and that they were told that the car needed to be put on a dyno and tuned. So needless to say they want to send it over to a local speed shop for a dyno tune.
I am still out of town and basically at their mercy - mainly because I want my car!!!! They are quoting me another $650 for the dyno tune. Theysaid that I will receive the tune where I can reload if needed in the future and that since they are having it done, all the records will be on file there in case an issue comes up later where it fails inspection or for some other reason that the car is in the shop they will not reflash it by mistake. Guess I just lose out on the new tuner and all that i just bought from Doug.
Anyway, I need help understanding what they could possibly mean when they said the car did not seem balanced. Any help would be appreciated.
FRPP 3.73. Gears
Steeda UDP
RE: Help with Hot Rod Cams
imo, you should wait until either you
or a friend can evaluate the car and
how it is running, before you shell
out more money.
my guess is it's idling a little rough and
the tech thinks it should be smoother..
out more money.
I swear there are no true mechanics anymore the computer couldn't spit out any thing so he thinks the motor is out of balance??? Tell them to give you your car and you'll take care of it and just use Doug's tune.The cams are doing what they are supposed to do!! $650.00[sm=WTFsgign.gif] for what? If they want $650.00 ask them for an invoice broken out showing exactly what they are doing
and if he says it just labor hours don't buy it make him put in writing what they are doing.
ORIGINAL: howarmat
im guess a new tuner and tune, so 650 is about right for that perhaps
ORIGINAL: jmose77
[sm=WTFsgign.gif] No where near right. You can get an SCT tuner from Doug with three tunes for $379.00 the tune he made for these cams was from a car he had on his dyno. MyLocalDJ do not pay them $650.00. It is not worth it I am running these cams with Doug's tune and everything is fine. Besides that he already has the tuner and tune from Doug.
ORIGINAL: howarmat
Why do you say that......obviously he already got a tuner and tune from doug, but what if its a diablo and shop that the dealership wants to take the car to only uses the SCT. So 650 for a different tuner and dyno tune isnt that far out......im not saying he should do that but you asked what the 650 was for and i was answering you.
+ and - ^^^ I would pick the car as is...seems all the work is done and Doug's tunes is loaded. You may want to later put it on the dyno, data logit and send it to Doug. At that point, he should be able to change some things around if needed. Not every car with the same parts is going to run the same as the next one.I have seen plenty of cars with the same setup and tune,produce different a/f ratioand power #s.
Have fun with the new set up!!
Casey
Casey
ORIGINAL: howarmat
ORIGINAL: jmose77
ORIGINAL: howarmat
