cams
it ahs been proven the COmp NSR staeg II's produce 25-32hp threew out the rpm band. the FRPP cams sound better but don't perform better. The comp NSR are the NSR cams out there the dont lose anything down low and gain up top. radmustangs.com have a dyno sheet so you can see the gains.
comps spr are bad *** but the idle isnt there and cost a fortune to install...
There is a thread on here somewhere with both comp and frpp dynoed and comps looses torque down low where the frpp dont and as I stated before the hp gain is not as large as the torque diffrence so IMO the frpp ones are better , Im not interested in the extra 2 hp at 6000 rpm more concered with having torque down low or atleast maintaning my current tourque level.
oh, and cams are free to install...do it yourself
With comps new phaser limiter lockouts, they are able to harness a very nice amount of low end torque while keeping the high end gains very high...they limit the amount of degree to a high of 20 degrees as opposed to high 60's as with normal cams in the mustangs
Rememebr we are comparing apples with apples and if it came down to it im sure ford could release spr cams also that gain you high hp but im sure they do there homework as well and there isnt much of the market for it at this point considering the spr have been out for awhile and I recall maybe seen 2 guys on all of the forums im on with them.And installing the spr compared to the nsr is like a $1000 diffrence at a shop, and they dont charge that amount either cause its easy to do, nsr sure not to tough adding all the stuff included in spr is a whole diff story.
does anybody have any dyno charts or a link for the spr im curious to see what they put out?
hot rods sound amazing.... i want them!!! do you need springs and all of that? would it be the same if i modify my stock cams? i have a friend that works on the crower factory and we said he could modify my stack ones and make them a replica of the hot rod cams. whould this be a good idea?
good choice
NSR No springs required (according to the FRPP website)
if you can create a duplicate of the hot rods, with your cams, then
yes it would be the same
i don't see why it would not be a good idea, except for the down
time.
good luck, i hope you get your cams, one way or another
good choice
time.
here is COMP NSR stage 2 for slight comparison..
Test Parameters
Engine: Ford 4.6L Modular 3 Valve Engine
Intake Modifications: JLT Cold Air Intake
Headers: Dynatech Full Length Headers with X-Pipe & High Flow Cat
Mufflers: Stock
http://www.compcams.com/Base/masteri...no/nsrdyno.jpg
Test Parameters
Mufflers: Stock
and for you guys wondering what the difference is between COMP CAM stage 2 NSR and COMP CAM STAGE 2 SPR( Springs and phase limiters) Here is the other chart and a video.
http://www.compcams.com/Base/masteri...no/sprdyno.jpg
pretty big gains and no lose of low torque.
Heres the video if you want to hear what they sound like.
http://www.powerperformancetv.com/vi...l.php?mId=5294
Also for you boosted guys... Brent at brenspeed recently did a COMP CAM STAGE 2 SPR (Spring phaser limiters) blower grind. He got amazing results out of it.. 85rwhp!!
http://www.powerperformancetv.com/vi...l.php?mId=6536
there is brents video and dyno results at the end.
