MAC prochamber
MAC prochamber
If the O/R MAC prochamber was installed, would it cause a horsepower/torque loss? due to not enough back pressure?
I currently have Pypes mid muffler exhaust, and was thinking of adding a MAC O/R prochamber. However I want to check:
Do I need a flash/program?
Does it cause HP/Trq loss?
How hard is the install? (I'd have to reinstall the cats in a couple years for emission inspection)
Any help would be appreciated.
If you go with the direct replacement pro chamber, it is a bolt on deal. You can easily remove it and put the stock mid pipe back in. You will only need a tune if you currently have cats.....need to turn off rear monitors for the cat deletes.
Casey
Casey
What would happen If I installed the O/R Prochamber without a tune? Would it run rough with the heck engine light on?
I know everyone says first mod should be tune + intake, but thats over $600.
