Am I screwed?
Am I screwed?
So I just got back in town and tomorrow I'm going to put the stock O2 Sensors back on. As to why the Bosch ones were supposedly "not working" I am clueless. If my car still throws the "Electronic Throttle Control" CEL then It has to either be a blown fuse, electric wiring, or some computer problem somewhere else.
Still...I am flabbergasted as to how an O2 Sensor going out could cause that...but I guess **** happens. The dealership that I bought the car from says they won't touch the car (they flashed and cleared some of the codes, but they said they won't touch it until its back to stock.) So...If they won't touch the car...where can I go if there is a problem? Do I really have to take my exhaust OFF and then go back to the dealership, replace whatever problem is wrong, and then put the exhaust back ON?
What other place around me would have any knowledge on something this delicate?
Help greatly appreciated
No...I'm not saying they are horrible jerks or anything...I'm just saying something is wrong and they will not help while It is not stock. I am asking for options before I take the time and pay thousands (or something like that) to put it back to stock...so I can then try to find the problem, and then put the exhaust back on.
I would rather find a way to fix this or at least FIND the problem first before I go through all that effort and spend all that money just so they will "try" to help me.
And yeah...the Electronic Throttle Control CEL came on right after my O2 sensors went out on the road at like...idk... 30 mph. So I'm -fairly- certain it is -because- of the O2 sensors going out...not that the CEL is still on because of the O2 sensors aren't the right ones.
I'm saying I think the O2 sensors blew something out...idk what or how or anything. Fuses or wiring or something like that.
Why would another dealership help me out with my problem when they will INSTANTLY know that I have aftermarket exhaust? lol.
Yopr problem seems like the exact problem I had. I took it to the dealer and they said since I had a Kenne Bell at the time the CPU was moved and they said the heat had ruined it. They wanted 1100.00 not covered under warrenty. I called another Mod friendly dealer had Ford roadside assistance haul it out there for free and they fixed the throttle positioning senser and replacer the TB under warrenty. Fixed the problem.
Thanks! I wonder if worse comes to worse If I'll have to buy a mid pipe with cats and install that. But...then I'd probably have to get it welded because it wouldn't fit right...
Lol...So a dealer that sells Roush or Saleen might look at it even without Cats?...idk about that.
Thanks though
Thanks though
Maybe get a set of high flow cats welded in? Get them welded in with flanges then you could just unbolt them in favor of a pipe. I guess that way if you ever needed warrantee work again you could just change out the segments and get it taken care of.
You need to try another dealer and learn more about what is going on, the exhaust is not causing problems with your throttle body. If you have the CEL still pull the actual code and come back to us.
