Changing Spark Plugs *Question.*
Old Oct 15, 2008 | 02:59 PM
Explosive's Avatar
Explosive
Default Changing Spark Plugs *Question.*
Alright, my friend just changed his plugs, I'm making this thread so I have something to compare with.
He has an 04 Crown vic police interceptor, it has the 4.6L Since it has aluminum heads I told him, use anti seize on your plugs and torque them by hand so you don't strip them.
He has an account on a crown vic forum, he asked for their opinion, they said change the plugs dry, and don't use anti seize or anything similar to it.
He second guessed them and asked if they were sure, and they bascially called him an idiot for not taking their advice and doing it like they had said to. I went over my friends last night, helped him change the plugs, did it the way I said, with anti seize and no torque wrench, just by hand. Everything went fine, car runes fine ect.
So, whats your take ? You're the guys with the 4.6
Old Oct 15, 2008 | 03:10 PM
P71Vic's Avatar
P71Vic
Here's a Link to the thread.
[URL="http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=1582295#Post158 2295"]
Old Oct 15, 2008 | 03:13 PM
Explosive's Avatar
Explosive
Fixed link,
http://www.crownvic.net/ubbthreads/u...nt=all&fpart=1
You can figure out where I came in...
Old Oct 15, 2008 | 03:52 PM
atomicpunk's Avatar
atomicpunk
When you put steel and aluminium together you get electrolysis between them - an electric current that can causes them to seize together. When replacing plugs in an aluminium head I always use high-temp antiseize, cheap insurance.
Old Oct 15, 2008 | 04:12 PM
Texotic's Avatar
Texotic
why not use it? if you don't need it, oh well. if you do and you didn't use it, have fun paying to have your broken plugs pulled out.
Old Oct 15, 2008 | 04:16 PM
Explosive's Avatar
Explosive
They told him not to use it because it throws off torque wrench reading. Who the hell uses a torque wrench for plugs ?
Old Oct 15, 2008 | 04:44 PM
cavediver's Avatar
cavediver
In aluminum heads, I always use a torque wrench! And yes, there is a difference between 'dry torque' and 'wet torque'. If you use too much anti-seize and don't torque the plugs correctly you run the real risk of the plug loosening and backing out.
Old Oct 15, 2008 | 04:45 PM
P71Vic's Avatar
P71Vic
Forum War
Old Oct 15, 2008 | 07:59 PM
Diabolical!'s Avatar
Diabolical!
Use the anti sieze, but not on the threads. On the shaft below the threads is where the plugs really lock up. Also, if you put the anti sieze directly on the threads, it increases the chance that the plugs will back out.
Old Oct 16, 2008 | 01:07 PM
SCCAGT's Avatar
SCCAGT
Crown Vic 4.6L's are still 2 valve engines. So the 3 valve mindset does not apply.
