removing stock harmonic balancer
use 5th gear and ebrake and a breaker bar and she will go ! yes use the steeda and none other i wouldnt even use the roush. When you use your pully puller you will need the 3 prong type to pull off the factory one and be sure to use a stop so the threads dont go inside your crank and strip your threads.
also dont listen to steeda do the install from the top with thte car on the ground. Just remove the rad shroud degas bottle power steering resivour and fan. Dont dran any of them just move them to the side and you'll be good.
M3hunter
09-05-2015 03:42 PM
