my estimate for HP add-ons correct???
tune/K&N cai...15-25
steeda - underdrive pulley...10
bbk - throttle body/steeda spacer...5-10
kooks - long tube headers & catted pipe(H or X...diference?)....15-20
cummulative...around 50?
am i anywhere close....overlooking anything??
thanks.
thanks.
trash the spacer 0 hp gain from that garbage and your probaly gona get maybe 5 -7 from pulley and LT depends on your tune I imagine if you had it on the dno you could pull the highest amount out of it.
Here's my take:
tune/K&N cai...15-25 - Probably more like 15-20. I believe the K&N has a smaller diameter than most other aftermarket CAI's
steeda - underdrive pulley...10 - More like 5-10
bbk - throttle body/steeda spacer...5-10 - zip, maybe 2-3 IF you're lucky. doesn't help much unless you're aspirated
kooks - long tube headers & catted pipe(H or X...diference?)....15-20 - sounds about right. If I recall, the X would provide minor help
My "gut" total: 40-45 (because I stayed at a Holiday Inn Express)
I'd guess your at 350 HP between the UDP, LTs & X-Pipe, and Tune/CAI. The Throttle Body stuff probably isn't helping judging from past posts about the way these cars respond to modding the TB.
PS: Get a Pypes Mid Muffler System... sounds wicked with the Kooks LT Headers & X-Pipe. Here is a video of them on someone elses car...
http://www.youtube.com/watch?v=e_Ftc82mT7I
edit: Yes I meant Crank HP not RWHP
Sorry gburke1 but there is no way he is anywhere near 350.
Stock manual = around 265
Pulleys: 7
TB/Spacer: 3, maybe
LTs/Midpipe: 15 (unless dyno tuned)
K&N/Tune: 20
Around 305 - 310, probably less unless you have a good tune.
Who is your tuner?
Pulleys: 7
TB/Spacer: 3, maybe
K&N/Tune: 20
Who is your tuner?
