Kenne Bell SC or Turbo?
No, the twin screws have a fairly mean sounding whine to them, where as the centrifugal produces more of a whistle along with a flutter when you let off the gas. Typically speaking anyway, the kits do vary quite a bit. I like the sound of the twin screws, but I'm not spending several thousand dollars based on sound effects, lol. IMO, pick the type of kit that works best for you in characteristics, price, power. Sound would be among the last things I would be worried about up front...
I know alot of people here on the forums say to go intercooled no matter what setup you run. It's safer and you get more power per pound of boost. Remember its not boost that is important, its fuel quantity so getting more air in the engine is key. If you take a can of air and heat it up, you'll see more pressure (boost), but you won't have any more air to mix fuel with. With an intercooled system, you can see the same RWHP for less boost as a non intercooled. Also, I live in Florida so it can get quite hot under my hood.
/Wants a Kenne Bell SC
i have the hellion turbo kit on my car and just love it. i have drove a ts and a cntri. before my car acts more like a ts rether than a centri. my # are below in my sig and was 102 shop temps in july when we tuned the car. a turbo will allways make more trq per pound of boost than any supercharger. the power will be the same or mabe just a little bit more than a ts usually.
Get a turbo. You can go bigger cheaper later and your upside is more. TS's are fun but you have blet slip which is a pain. Yes you can get an 8 rib setup but that's just another grand in the bucket.. Then there's the $200 pulley's you'll need. Get a good turbo and thank me later...
i agree with blueherd02gt totally. i have been around supercharged carsfor a long time and turbo cars for a wile and i have seen and been converted to turbo. ther eis just more potential in the long run. and as for mudflap once you get to 400 hp you will want more beleave me on that one and when you do a kit go over board on the fuel system. i went with 60lbs injectors, fore percision hat with 2 gt pump kit like the one from www.leathalperformance.com, and get a mafia you may need it in the future or even then. i have a 5.0 stroker motor being made as we speak, heads from fox lake, and cams from blow by racing on the way along with there valve springs. i am hopeing for 650hp on 93 octane pump gas and 800 on 110 octane race fuel. the turbo i have now is good for 650-700 to the wheels. so i will be up grading to a dual ball bearing turbo as well.
