My battery dies, install a new one, car runs aweful
I don't understand why this would happen when all I'm doing is installing a new battery. I have a CAI, CMDP, SCT tune with a Brenspeed tune and an x-pipe.
What happens is, when I start it up in the morning (cold only) it acts like it wants to die and runs really rich. After it warms up for about a minute, everything is fine and it runs well. Does anybody know what's going on from a simple battery install?
Thanks for your help...
Thats a wierd one. Try re-loading your brenspeed tune again. Possibly was corrupted when your battery failed. Or you may be experiencing altenator faults, but usually they set a check engine light and you didnt state that.
it wouldnt be the altenator if it was first your car would run fine off the battery till it drained it. then your car would die. it sounds like its got to be the tune. since your comp probably is back to stock now. if that dont help its probably got a curse on it...try holy water... from what i hear you have to put in your master cylinder and it some how works its way out of the brakes and into the engine....
Hey, Thank you all for your replies.
1. I have two tunes (Bama 93 race tune and Brenspeed 93 tune) both of them do the same thing. I thought it was the tune too, but when I first installed the battery nothing worked right. The windows wouldn't roll down so I could open the doors and the car wouldn't run at all untill I installed the tune.
2. This isn't my daily driver and this has been going on for about 4 months (approx. 2000 miles). Very few times has it not done it and it started up just fine in the morning.
Do you think I need to disconnect the battery for about an hour, reconnect it and then install the tune before starting it?
What do you guys think?
Autozone midgrade. The only thing they had for this car. I disconnected the battery and I'm completely removing the tunes on the SCT tuner and reloading them from my computer and I'll see what that does.
I'm wanting to install some thumper cams, but I've got to get this issue handled first...
I do believe that I got it resolved!!!!
I disconnected the battery for about 40 minutes and reloaded the tune on the SCT device and to the PCM.. It started up just fine (better than before all of this) and runs very well.
Now, it's time for those thumper cams... yes, yes, yes
Thank you all for all of your help!!!!
