Gauges for a Saleen supercharger
I have a Brenspeed Saleen stage 3 supercharger , and woundering what if any gauges would be recomended to be used? I was thinking a fuel presure, electric or mechanical ( i think electric) and a boost gauge and water temp, can the s/c temp be watched separate from the engine temp. any suggestions thanks
I have been researching the same thing since I have bought/need to install a SC. I am looking at wideband air/fuel gauge, and FYI, certain Auto Meter's have a $50 rebate thru end Feb. Go to their site for form.. brenspeed sells the 6178, expensive, but not really cheaper anywhere else.
Boost is the other, but I can buy a sensor for my aeroforce interceptor for that. Look forward to more input from others with more experience.
Anyone know if these autometers A/f come with everything needed, and does it take a sensor mounted in exhaust system?
I just ordered a sensor kit for one of my aeroforce gauges to measure boost, and plan to buy the autometer A/F.
All wideband gauges requires the sensor in the exhaust, correct? I assume the gauge comes with all that is needed, just have to get a bung installed welded in for a sensor?
PLX-DM5SMA... PLX DM-5 & SM-AFR 2-1/16 Digital Display &
Air Fuel Sensor Combo (Blk/Blk)
INN-3735 Innovate Bung/Plug Kit
You can get the A/F gauge seperate, so make sure when you order you get the kit.
if you dont really run the car at a track a lot, then I would just stick with boost/vacuum, and air to fuel. thats all I have and pretty much need. Cobalt is a good brand if your are unsrue of what brand to get... They worked out perfect because they have a blue back light which matches my stock guages color setting...
