Quick response please!
Old Mar 25, 2009 | 09:26 PM
Brian_Zinchuk's Avatar
Brian_Zinchuk
Default Quick response please!
Its late and I need to put a quart of oil in my car before it gets dynoed tomorrow and the only place I can go is Wal-mart. Right now I have Royal Purple 5W-20 in my car and all they have here is royal purple 5w-30 or a different brand of 5w-20 such as mobil 1. What should I go with? Its not going to really effect the engine putting a quart of 5w-30 in with 5 quarts of 5w-20, will it?
Old Mar 25, 2009 | 09:30 PM
gtguyonli's Avatar
gtguyonli
Id stick with the 5W-20 in a different brand. I don't like to mix visconsities.
Old Mar 25, 2009 | 09:33 PM
hotairgypsy's Avatar
hotairgypsy
mix oils ok...mix dif weights... not ok
Old Mar 25, 2009 | 09:34 PM
Brian_Zinchuk
for sure?
Old Mar 25, 2009 | 11:13 PM
SirKnightTG's Avatar
SirKnightTG
My current oil is one quart mixed. I have 5q of 10w-30 and 1q of 5w-30 (same brand and full synthetic). I've had the oil for a little over 5K miles in there. No problems at all. It's not like this is a top fuel drag car.
Old Mar 25, 2009 | 11:26 PM
RainsFather's Avatar
RainsFather
Mixing different weight oil is a bad thing. Mixing different brands is very common, even mixing different types like say you put 5qts of synthetic and one quart of non synthetic is ok. Different weights don't mix well and you get build up.
Also, yes your car is not a top fuel dragster, they tear those down after every pass, you expect your car to last a while and any type of oil build up can keep good clean oil from getting where it needs to go.
Old Mar 26, 2009 | 01:17 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
what they said! ^^^^^^^^^^
Old Mar 26, 2009 | 11:02 AM
SirKnightTG
Well all I know is it's perfectly fine and one quart with a very small different weight is not going to hurt anything.
People get so paranoid over oil for no good reason.
Old Mar 26, 2009 | 11:17 AM
Brian_Zinchuk
Well it all worked out I put a quart of mobil 1 5w-20 in it and it runs fine. Thanks for the help guys
Old Mar 26, 2009 | 12:24 PM
Nuke's Avatar
Nuke
Too late. I was going to say that I'd rather mix the 2 Royal Purples than mix M1 with the Royal Purple. The reason being is that both weights of the RP most likely have very similar additive packages whereas the packages in the M1 may not mix well or may even detract from both oils properties. Regardless, you should be fine with the M1 for awhile. I'd just change the oil at the earliest convenience.
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
CS2007
Sep 29, 2015 12:06 PM
Sep 25, 2015 06:30 PM
