CMVD Plates
Honestly, if you can't weld you might be able to get away with filling the holes with JB weld or something similar.
The theory is that even when the valves are open during WOT, the small cross section of the valves when open blocks a small amount of air flow. You give up a little low end torque which some tuners have been able to tune around, and a little bit of fuel economy. I would recommend doing delete plates at the same time as another mod such as a UDP so you can feel a bigger improvement.
charge motion valve delete
CMDP- also known as charge motion delete plates
benefit
http://www.fordracingparts.com/parts...tKeyField=9123
Removes restriction of CMCV (charge motion control valves) blades and shafts
more air is flowing and more fuel is required and most of the time you get a tune for having them to increase HP
benefit
Tell ya what, my tuner is actually gonna do a Pull and Swap on a stock '08 Bullit later this month. If you are willing to wait, I will let you know the results from the Dyno. The plan is to make a pull, swap the plates, make a pull, then dyno tune the car and make a final pull. My tuner (link to the shop is in my sig) has plenty of tuning experience, so the results should give us some real numbers.
HTH
~Matty
HTH
~Matty
HTH
~Matty
HTH
~Matty
Jeff
HTH
~Matty
HTH
~Matty
I would not recommend doing the swap on a street oriented bolt-on NA car.
