Which should be the Next Mod??
I allready Have FRPP Stingers and a O/R Hpipe, and Brenspeed Cai and tune. Which Mod Should i do next. Mac LT'S with O/R Prochamber or Comp Stage 2 Thumper Cams or U/D Pulleys with C&L Intake Manifold? I know the manifold doesnt come out for awhile..I just need some input on which one you guys would perfer.
Honestly if you are considering all those at some point or another you should really just save your money for an SC. You could do the Vortech system cheaper then the parts and labor would be on that stuff and see a good 100 hp more.
OP, I say get the LTs or a set of gears. If you go get cams you might need the gears depending on the cam you select.
Gears or headers, then cams. You really need the first two to properly take advantage of cams. You'll need the gears to get up to your new powerband quicker (and to offset any low end loss that some may have, but even then it's only a little). Also you'll need the headers to help with the flow to maximze your cam's gains.
I'll be doing headers here really soon myself, then gears then cams (and suspension somewhere inbetween, lol).
