Front control arm bushings worth the effort
The smaller urathane and clamp set-up and not for DD use.
There is a slight risk factor with failure under extreme loads.
OK for the increased performance/increased risk but for the DD??
Do you really want the increased failure risk?
Im getting ready to install the Steeda bushings from the above link this sunday. Anyone have any more info on the performance ? Anyone here have a failure ? What is the failure concerns mentioned by 157db ? I thought the hydra bushings were more of a risk than anything, (swapped out the hydra motor mounts for prothanes and love them).
Steeda pretty much lays it out in the product description, use red for slightly better then stock with tolerable stiffness and road noise or use black for more precise corners but there will be harsher ride and noise.
Race course only. Maybe just a disclaimer.....
The hydra bushings are captured and dont seperate during a failure.
The steedas come apart when they fail...
i dont see the disclaimer on the link above....i do however see that on the hydramount bushing replacements
